Datum Line
Argyll
Has thanked: 1180 times
Been thanked: 579 times
Datum Line
Post by Argyll »
I'm currently fitting a kitchen and working out the datum line. I've found the highest point in the room (5.1 x 2.4m) and marked 870mm. However, there's a deviation of 20mm at some points. I've read elsewhere to mark the datum line in the middle i.e. 860mm so there's only a deviation of plus or minus 10mm. This is so there's not a large gap on the kickboard.
Whats your opinion on this?
Has thanked: 814 times
Been thanked: 3508 times
Datum Line
The focal point will always be the worktop. The kickboard is usually black, in the shadow of the carcase overhang, and is largely invisible. I would pick a point that gives you a gradual gradient for the ground line cut so it is a fairly easy straight cut. I was tempted to buy a cheap laser level in Aldi but did not in the end. I just looked on Amazon and there is a cheap generic type for £22 hmmmmm.
Argyll (Tue Oct 17, 2023 11:40 am)
Argyll
Datum Line
Post by Argyll »
I have a laser level mate. Just wondered if I should work from 870mm or not
Datum Line
I thought you would have, did you track the floor to see the rises and falls? As I said it is really only making the scribe easier if you can get an idea of the board to ground line. I am sure 870mm will be fine. I usually mess up scribes :lol:
wine~o
Has thanked: 1414 times
Been thanked: 4017 times
Datum Line
Post by wine~o »
I've only ever fitted 2 kitchens, and then I had to get a man in for the worktops, 860/70/80 depending on worktop thickness is about right.
Argyll
Datum Line
Post by Argyll »
I've encountered another problem that I hope you can help me with. I've set my datum line to 875mm from the floor at the highest point in the room (+5mm for vinyl floor). The problem is that the lowest point I've realised is lower than I initially thought so with the cabinet in place at the lowest point the gap at the plinth is 170mm. The kickboards are 150mm which will leave a gap of 20mm. This would be too great I reckon so I have two choices.
1. Either buy or make from MDF a 170mm plinth. I don't think I can buy a plinth that wide. I'm also cautious about having the cabinet feet too high so I'd use little wooden blocks instead to increase the cabinet height.
2. My preferred choice and easiest is to reduce the height at the highest point to 855mm. I'm 6'2" and the worktop might be a bit low for me but feel it's my only option.
I know the standard height when setting cabinets is 870mm but what height have you ever reduced it to?
What would you do?
Argyll
Datum Line
Post by Argyll »
wine~o wrote: Tue Oct 17, 2023 4:14 pm I've only ever fitted 2 kitchens, and then I had to get a man in for the worktops
No need to mate. I bought one of those square edge worktops so don't need to cut a masons mitre. Just square it up and use the locking bolts underneath.
wine~o
Datum Line
Post by wine~o »
Argyll wrote: Tue Oct 17, 2023 4:19 pm I bought one of those square edge worktops so don't need to cut a masons mitre. Just square it up and use the locking bolts underneath.
Great if all the walls are all square to each other.
Argyll wrote: Tue Oct 17, 2023 4:18 pm Either buy or make from MDF a 170mm plinth.
Plenty of options available if you look around for 170mm plinths (not B & Q though)
Argyll
Datum Line
Post by Argyll »
Doddle Wine O. Just lay the worktops over each other and mark from underneath. Then cut with a track saw. That's the theory anyway 🤣
I've considered looking at other plinths but maybe a different shade of white. Maybe not though. I'll have a look later. 👍
wine~o
Datum Line
Post by wine~o »
Argyll wrote: Tue Oct 17, 2023 4:58 pm Doddle Wine O. Just lay the worktops over each other and mark from underneath. Then cut with a track saw.
And that's why I "get a man in", If I did it myself and fecked up then it's down to me, get a man in. it's down to him... yes it'll cost me £££'s to get the man in, but I only need to get it wrong once to equal that equation.
Bob225
Has thanked: 99 times
Been thanked: 875 times
Datum Line
Post by Bob225 »
Living in old houses most of my life, level and true doesn't always look right
screw the units together and level them as a group
fin
Has thanked: 32 times
Been thanked: 805 times
Datum Line
Post by fin »
type of sub floor is it mate?
also i mostly fit howdens. their spec is 890mm from ffl to the top of the cabinet.
if its a concrete floor lose some of the difference with a smoothing compound.
if its a timb er floor then i guess a happy medium is best.
Argyll
Datum Line
Post by Argyll »
fin wrote: Tue Oct 17, 2023 11:11 pm type of sub floor is it mate?
Fin it's a concrete floor but its a big kitchen (5x2.4m) I really can't be arsed messing around with flooring compound. I might just drop it at the highest point to 855mm and live with it.
oz0707
Has thanked: 161 times
Been thanked: 68 times
Datum Line
Post by oz0707 »
All depends how far away from the plinths you will be to see any gaps. If galley style kitchen 20mm at top would be fine as wouldnt see. Tbf i wpuld want any less than 10mm gap between unit and plinth to get something in there to pull off. Otherwise you need a suction cup. If howdens spec is 890 what are their units fin 720mm high? What are their plinths 160mm?
fin
Datum Line
Post by fin »
cabs are 720 and plinths are er,,,,,,,, 165mm i think....
Return to “Kitchen Fitting”
