dewaltdisney wrote: ↑Sat Oct 28, 2023 11:50 am
PVA is the last thing in a damp situation as it is water based and reactivates when wet. It looks like you are dry lining plasterboard onto studs so I really do not see any need for further wall sealants as long as it is dry. I may have read this wrong?
thanks - yes, the issue was fixed last year, so I can confirm that the wall is definitely not getting wet now - though I did the seal as a precaution as there were still some low damp readings on it from where it hadn't fully dried out
I've not done plasterboard before but had read from this about using PVA to ensure the wall doesn't take damp from my adhesive:
https://www.buyinsulationonline.co.uk/b ... lete-guide
my thought was that the damp seal / stain block is already doing that, so was trying to figure out if I can skip the PVA step, or if I should still do it :)
thanks to you and @aeromech3 for confirming PVA isn't necessary :)
would you know if the above website is correct in stating that PVA should be used on other (non damp seal stain blocked) walls before dot and dab? :)
