Advice on removing internal plaster beads
Samwp
Post by Samwp »
We have a number of window reveals that might need to have the existing metal corner beads removed. I am looking for any advice on a way to remove the beads without causing too much damage to the rest of the wall. Any first-hand advice would be appreciated?
We known that the existing the beads are plastered on, not nailed.
Has thanked: 47 times
Been thanked: 2590 times
Score as close as you can to the bead into the plaster. The scored line should stop any crack in its track.
Samwp
Post by Samwp »
Thanks for the reply.
A knife with a straight edge was my first thought too. I was also thinking of using an oscillating saw with a curved blade to run down the edges, if a knife wasn't up to the job.
Return to “Plastering Forum”
