Which is the quicker way to dry the plastering?
Dxc712
Has thanked: 166 times
Been thanked: 3 times
Post by Dxc712 »
My kitchen was plastered earlier this week and I was told that plaster dries quicker in hot weather than in cold.
As it's cold at the moment (unfortunately), I have two options, leave the windows open or keep them closed.
Which will dry the plastering quicker in the cold weather?
Has thanked: 823 times
Been thanked: 3560 times
Let it dry slowly otherwise it will crack or craze.
Dxc712 (Fri Nov 10, 2023 10:14 pm)
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
Ventilation is the key. Excessive heat is a huge mistake
These users thanked the author Neelix for the post:
Dxc712
Post by Dxc712 »
dewaltdisney wrote: Fri Nov 10, 2023 9:41 pm Let it dry slowly otherwise it will crack or craze.
It is drying slowly. The heating is off in my flat (as it always is).
Should I have the windows open or closed?
Dxc712
Post by Dxc712 »
Neelix wrote: Fri Nov 10, 2023 9:59 pm Ventilation is the key. Excessive heat is a huge mistake
Do you think I should have the windows open in this weather?
Maybe just a crack to let the moisture out. As you have no heating on the fabric of the structure will be cold and opening the windows will not hasten drying and the moisture released will condense on the coldest surfaces.
Dxc712 (Fri Nov 10, 2023 10:33 pm)
Dxc712
Post by Dxc712 »
dewaltdisney wrote: Fri Nov 10, 2023 10:30 pm Maybe just a crack to let the moisture out. As you have no heating on the fabric of the structure will be cold and opening the windows will not hasten drying and the moisture released will condense on the coldest surfaces.
Thank you :)
Neelix
Post by Neelix »
Dxc712 wrote: Fri Nov 10, 2023 10:15 pm
Yes. Plaster contains a large amount of water - it needs to escape the room
Dxc712 (Fri Nov 10, 2023 11:06 pm)
Dxc712
Post by Dxc712 »
Neelix wrote: Fri Nov 10, 2023 10:35 pm
Thanks. I wasn't sure if opening the windows and making the room colder would slow down the drying of the plaster.
Has thanked: 736 times
Been thanked: 2341 times
would a dehumidifier not both give gentle heat and remove moisture aiding drying ?? :dunno:
Dxc712
Post by Dxc712 »
big-all wrote: Sat Nov 11, 2023 12:16 am would a dehumidifier not both give gentle heat and remove moisture aiding drying ?? :dunno:
I read that a duhumidifier could crack the plaster.
Dxc712
Post by Dxc712 »
I ran the water in the kitchen just now and a few drops went on the plaster.
Is this a problem or am I worrying unnecessarily?
I've attached a photo.
Ktuludays
Has thanked: 250 times
Been thanked: 212 times
Post by Ktuludays »
It's perfectly fine
These users thanked the author Ktuludays for the post:
Dxc712 (Sat Nov 11, 2023 9:30 am)
Preempting a potential disaster will be to know how to paint this new plaster. You will need to do a mist coat, an ordinary emulsion watered down to 4:1 paint/water mix. This will sink in and provide a good key for the finishing full-strength coats.
Dxc712
Post by Dxc712 »
dewaltdisney wrote: Sat Nov 11, 2023 9:18 am Preempting a potential disaster will be to know how to paint this new plaster. You will need to do a mist coat, an ordinary emulsion watered down to 4:1 paint/water mix. This will sink in and provide a good key for the finishing full-strength coats.
Thanks.
What's the potential disaster that could happen?
Return to “Plastering Forum”
