Minimum screed depth and screed advice
Andrew
Has thanked: 3 times
Been thanked: 3 times
Post by Andrew »
God it's been a long time since I last posted here! Time flies....
So I have a very small strip of a concrete floor which is probably about 10mm max lower than the rest as I have moved a wall slightly and the two floors aren't the same height.
It's only about 2m x 25cm long.
I was planning on just painting some sbr on the floor, mixing up some sharp sand and cement and laying that in there as best as I can, although sharp sand isn't the best idea tbh.
Can anyone please advise? It doesn't need to be perfect.
Cheers.
Has thanked: 807 times
Been thanked: 3498 times
I would consider self-levelling compound for that depth. You can go to 30mm'ish but over that it is best to screed.
Andrew
Post by Andrew »
Cheers.
I've never used self leveling compound. Does it matter if the floor isn't 100% level in the first place, ie you can work it to your requirements?
Also, does it need bonding or just go straight onto existing?
Have a look at this and get an idea https://www.youtube.com/watch?v=vc_5eAKILiY
Return to “General DIY forum”
