Thermostatic radiator valve not working
SRJDIY
Post by SRJDIY »
Hi, apologies if this is a daft question, but the valve on one of my radiators doesn't seem to be working.
The dial turns fine, but turning it doesn't turn the temperature of the radiator down. I've tested it by touching the radiator, then turning the dial and waiting an hour before touching it again, at which point it feels the same as it did before. The other radiators in my house look like they use the same type of valve; I've tested one of them the same way and it works fine.
Does anyone know what might be happening please? I've attached a picture if that helps.
Has thanked: 807 times
Been thanked: 3498 times
what often happens is that the valve pin can get stuck. If you are lucky you can remove the top you can tap it and free it off. This will save a thousand words https://www.youtube.com/watch?v=dwh3-JSQxWw
