It's the time of year when I put the xmas lights out and I always have trouble routing the cable around the wooden door, so I want to drill a hole around 20mm wide in the hardwood panel under the sidelight.
What can I use to block the hole up the rest of the year, I was thinking of a tap hole blanking plug but it would stand out not being wood colour.
Has anyone have a better idea?
Removable bung for timber door frame
- Gadget
- Jack Of All Trades
- Has thanked: 344 times
- Been thanked: 342 times
One of these? you could paint it any colour you like.
https://www.amazon.co.uk/Plastic-Covers ... 7f6b5&th=1
By eck! ©
- big-all
- Pro Carpenter
- Has thanked: 735 times
- Been thanked: 2339 times
top or bottom off the door frame away from the main line off sight or even behind the bell push double sided tape temporary moved a bit in the festive season
