Hi, is changeing a water pressure sensor on a gloworm ultracom 18sxi easy ? Could it be a diy job ?
Ive got F9 flashing up on my boiler when it fails to ignite, its not low water pressure as this was fixed last year with a new pressure exspansion vessel, and pressure is still at 1.3 bar, so im assuming changeing the water pressure will fix the problem....
Thanks guys
Water pressure sensor Gloworm 18sxi
- Has thanked: 10 times
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Firstly go to the Forum Index scroll down to Plumbing Forum and then across to 'Boiler Manuals', click, then down to Gloworm and look for your model installation; if _18sxi it will be under section 15.20; if model 2_18sxi will be 19.4.4 however the diagram numbering does not tie up with the text..
If another model mark be more specific.
Please report back so we can all learn!
- LowWaterSensor 2_18sxi.png (31.86 KiB) Viewed 4350 times
- LowWaterPx.png (38.52 KiB) Viewed 4350 times
