Looking for advice on kitchen flooring
Dxc712
Has thanked: 151 times
Been thanked: 2 times
Post by Dxc712 »
Hello
Sorry if I've posted this in the wrong part of the forum. I wasn't sure which section this should go in.
I'm looking into different flooring options for my kitchen. My main concern is the flooring getting damaged by something getting dropped onto it.
This is why I probably won't have the floor tiled.
Can't anyone recommend a type of flooring that I could use in that case and whether there are any particular pros and cons to that type?
Has thanked: 807 times
Been thanked: 3498 times
I would always go with vinyl flooring. From cheap sheet to Kardean, the flooring is warm, tough and looks good
Dxc712 (Wed Dec 20, 2023 1:18 pm)
Dxc712
Post by Dxc712 »
dewaltdisney wrote: Wed Dec 20, 2023 12:27 pm I would always go with vinyl flooring. From cheap sheet to Kardean, the flooring is warm, tough and looks good
Thank you.
Is it something that's less likely to not get either damaged or visibly damaged by something being accidentally dropped on it?
I have had vinyl type flooring for years and never damaged it in any way. Sheet vinyl can be quite cheap, Karndean looks nice but it is pricey have a read https://www.karndean.com/en-gb/floors
Neelix
Has thanked: 117 times
Been thanked: 212 times
Post by Neelix »
What is your budget and how big is the area you want to cover?
fin
Has thanked: 32 times
Been thanked: 805 times
Post by fin »
lvt is good. but the glue down type not the click stuff. thats like the karndean stuff.
Nos
Has thanked: 2 times
Been thanked: 80 times
Post by Nos »
A tiled floor is stronger than you think, have dropped bottles on it but not a pan as yet, but to have tiled you need a good base, we are a new build so the floor is concrete, as its our first tiled floor, the whole house is tiled as we have UFH, around the hob area you will be surprised at the amount of mess that is made when cooking, so as above I think vinyl may be best for you.
Hi Nos, it is a long time since you have been around. I trust your house is all complete now?
Return to “General DIY forum”
