Myson Thermostat
gambo
Myson Thermostat
Post by gambo »
Hi. I have just moved into a house that has a Myson Touch thermostat in one of the bedrooms. The temperature overnight was very cold so I'm trying to see if there is a way of keeping the radiators on constantly for a few hours overnight.
I can see from the instructions that you can set the temperature but you can't seem to tell it to keep the radiator on constantly regardless of room temperature. In my old place we had an old fashioned control where we could choose from timed, constant and off. Is it possible to tell the Myson to keep the heating on regardless of room temperature?
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Myson Thermostat
Post by aeromech3 »
Does this look like something you could manage.
Razor
Has thanked: 483 times
Been thanked: 1251 times
Myson Thermostat
Post by Razor »
It sounds like you need to get the myson swapped out for a programmable thermostat.
Then you can have what we call a 'set back' temperature so you can prevent it from dropping below a certain temp when you don't need the house to be at full temp.
You'd have one installed then just leave the main programmer on constant for heating and the stat would control things
