Painting exterior masonry
Jonnyuno999
Post by Jonnyuno999 »
Hi, I'm about to re paint the front of my house which has the old paint pealing off in places. I can't rake it all off its just loose in patches. If I paint straight over it the patches will stand out. Is there any type if plaster I can use to fill the patches bearing in mind that it would be a very thin coat ?
Has thanked: 47 times
Been thanked: 2556 times
If there was, (I don't know) what would said plaster/cement etc adhere to? What I am saying is, if you "stick" something to something else that is already lose, how long before it falls off?
Jonnyuno999
Its not loose its just where the paint has pealed
Has thanked: 807 times
Been thanked: 3496 times
Teh usual remedy is to use a stabilising solution as a primer, you need to use a water-based masonry paint over it. Have a look https://www.wickes.co.uk/Wickes-Masonry ... L/p/214145 and read up on stabilising solutions to get an idea of it will work for you.
