Toilet seemingly leaking around pan new connector
Luqy91
Has thanked: 14 times
Been thanked: 1 time
Post by Luqy91 »
I recently got a new toilet and 90° pan connector. The pan connector fits snuggly, but for some reason whenever I run my fingers around the pan connector to check for leaks, it feels wet, even the flat area just under the spigot feels wet but I haven't observed a leak (no dripping or spray, nothing). I'm assuming it's condensation, but is it normal to have a lot of condensation around and under the spigot?
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
Not normal, picture would be good as cannot imagine flat area.
fin
Has thanked: 32 times
Been thanked: 816 times
Post by fin »
had a few toilet pans from wickes that have had a bad seal with pan connectors.
Luqy91
Post by Luqy91 »
The area immediately around the new pan connector and "made in UAE" bust is what feels slightly wet to the touch. Water isn't pouring down from top to bottom, but simply emerging on its surface (which is why I assume it may be condensation?). The area that feels the most wet is the exposed porcelain (dark blue line). The toilet has been in use for one day and so far all seems good. Interestingly, the wetness has disappeared?
The reason why I'm a bit on edge, is because I initially fitted the new toilet with the old pan connector, only to discover a pool of water gathered under the front of the toilet 30 mins later. Since refitting the toilet no such pool has appeared at the front.
Has thanked: 831 times
Been thanked: 3628 times
The pan connector has baffle rings that create a seal when you push the spigot in. I have had one leak like that in the past and I simply pulled it back and forth a couple of times to get the baffles to grip uniformly. Try that it might help.
aeromech3
Post by aeromech3 »
And you did smear a little diluted washing up liquid around the porcelain contact area before sliding the connector into position.
Luqy91
Post by Luqy91 »
aeromech3 wrote: Mon Jan 29, 2024 2:56 am And you did smear a little diluted washing up liquid around the porcelain contact area before sliding the connector into position.
No. I only put a slither of soapy water on to both ends of the pan connector: the seal that slips over the spigot, and the seal that slips into the waste pipe.
These users thanked the author Luqy91 for the post:
aeromech3 (Mon Jan 29, 2024 7:56 am)
aeromech3
Post by aeromech3 »
I guess, if lined up nicely and no side or vertical force then, despite it looking good, what brand of 90*.
I only say this as some cheaper models use inferior rubber and the seal profile and number of ribs might be inferior to say McAlpine.
Some castings can be bad, oval or rough edges and some have very short stubs which don't engage fully into the sealing ribs.
Labyrinth style seals.
Luqy91
Post by Luqy91 »
This is the one I got https://www.toolstation.com/90-pan-conn ... lsrc=aw.ds
My old pan connector was made by Viva, and to be honest, the plastic felt a lot better on the Viva, but the seal on the Aquaflow seems to be just as good as the Viva when it was brand new. Ideally I would've purchased a McAlpine, but they were out of stock and the job needed to be done asap, as my mother suffers from osteoarthritis and I didn't want her to keep on having to climb to the 2nd floor bathroom.
Return to “General DIY forum”
