Creosote Nightmare
Rzw
Creosote Nightmare
Post by Rzw »
BeenWorkin wrote: Tue Aug 17, 2010 11:49 am I am going to try a couple of coats of wood sealer then 2 or three coats of clear varnish in an attempt to keep the remaining creosote safely locked away. Will report back with results.
Hi, what did you use and did it work? I’ve got the same issue going on and need to seal the wood to stop the creosote weeping. Any advice would be great. TIA
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 569 times
Creosote Nightmare
Post by moderator2 »
Rzw, The thread you dug up was from 2010. The OP hasn't been back since. I've split your post and started you a new thread.
Original thread here viewtopic.php?t=32669
toolbox
Has thanked: 129 times
Been thanked: 210 times
Creosote Nightmare
Post by toolbox »
Horrible stuff to cover, I would try Zinsser BIN, two coats.
Otherwise depending on what it is perhaps overboard.
