Repair gap between external wall and concrete slab
udaman
Has thanked: 159 times
Been thanked: 17 times
Post by udaman »
Hi
There are some areas around my house where there's a gap between the concrete slab/path and wall. In at least one place the water is getting in enough to make the wall wet inside the house.
What's the best stuff to use to fill the gaps?
Should I look to fill the gap with on product, and then put in an angle section of concrete to add a second layer of protection and to direct water away?
If I should be using concrete or mortar for the repairs, what mix should I use?
Or am I barking up the wrong tree completely?
Any advice much appreciated.
Cheers
Has thanked: 47 times
Been thanked: 2559 times
Pictures would help, pictures of the offending area would be even better.
udaman
Post by udaman »
Yes, sorry. I'm at work and didn't think I had any to hand but turns out I have. Ta
udaman
Post by udaman »
Any thoughts anyone? Ta
udaman
Post by udaman »
Good weather and a BH weekend, so hoping to get something done with this this weekend...
If nothing else, I was thinking to remove the existing knackered fillet, repair obvious cracks and defects in the ground-wall join with a concrete repair mastic, followed by a new fillet. I figured and hoped that if this worked in the past hopefully it will again.
I've no idea what mix of cement to use, whether to use SBR, etc. - so any thoughts on that would be great.
And any other thoughts most welcomed too.
Many thanks
Return to “General DIY forum”
