split pebble wet room
prem
Been thanked: 17 times
Post by prem »
Just about to do a wet room (shower area ) in split pebbles, what is the best grout to use with the bigger than normal gaps you get with these tiles? Using Ardex flexible adhesive, or anything better out there. Been out of the game for a while.
cheers
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
Are they attached to a backing and then you will use Ardex?
What is the substrate (concrete, backer board, wood)?
For grout if you need colour then Ultracolor Plus FA by Mapei; if not Ultra Plus Max.
Are you going to use a sealer?
In Far East the actual pebble showers you find in resorts are just set in Thinset mortar!
Return to “Tiling Forum”
