How to enter consumer unit from outside wall
- Has thanked: 36 times
- Been thanked: 1 time
Hi, I am planning on getting electric to my detached garage. The garage is set back behind my garden at the back of my house.
I will be using a cantanary wire to suspend the cable. My consumer unit is at the front of the house.
I am going to get everything in place then get an electrician to connect the cable at both ends.
What is the correct way to enter the consumer unit from the outside wall? I don't really want any cable visible on the inside kitchen wall, can the cable enter through the brickwork and straight into the back of the consumer unit?
I have been advised that 3 core 4mm tuff sheaved cable is OK for this job and that it can run it off a 20A RCBO in my consumer unit.
The garage will have a light and a couple of double sockets that will barley get used.
Cheers
Cheers
- Screenshot_20240402_142808_Gallery.jpg (186.28 KiB) Viewed 317 times
- Screenshot_20240402_142804_Gallery.jpg (53.05 KiB) Viewed 317 times
- Screenshot_20240402_142753_Gallery.jpg (63.41 KiB) Viewed 317 times
- Screenshot_20240402_142740_Gallery.jpg (195.59 KiB) Viewed 317 times
- Screenshot_20240402_142730_Gallery.jpg (148.6 KiB) Viewed 317 times
- Screenshot_20240402_142718_Gallery.jpg (181.48 KiB) Viewed 317 times
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2556 times
It can often be done via rear entry, but you will need a "Wiska" (or similar) box outside to terminate the cable. Best ask the electrician what he will do.
- Has thanked: 117 times
- Been thanked: 212 times
I would consult a spark on this and your route as I think it’s not ideal but eyes on site always trumps random internet advice
And if you are thinking of adding it to the RCD side I would advise against it as cumulative leakage is be ing a bigger issue for CUs with this set up
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
Nothing to do with your original question, your gutters need clearing...
- Has thanked: 807 times
- Been thanked: 3496 times
Thanks everyone, I will get an electrician down to have a look. I will also clear my gutters haha. Cheers
- These users thanked the author James11 for the post:
- dewaltdisney (Wed Apr 03, 2024 7:07 am)
- ericmark
- Has thanked: 116 times
- Been thanked: 782 times
I also have a SWA cable running around the outside of my house, as too hard to route it inside due to type of floors. There is a list of cables which can be buried without the need for RCD protection for the cable, one being SWA, I have SWA and the RCD built into sockets, since the supply in my case is the UPS for the freezers better the RCD is were easy reset.
You may want the same with your garage supply, there is a huge jump from up to 13 amp, and over 13 amp as to what is required, the simple option is a fused connection unit in house, and a switched FCU in garage for the lights, but once you go over 13 amp, then looking at a consumer unit in the garage.
The problem today is the electric vehicle, if you want to charge one then in the main it needs some sort of current transformer to tell it total power being used so it can drop charge rate if the house has a heavy demand. So we use a special cable with some coms cores within the cable. It may be as well to use this type of cable even if you don't have an EV so it can be used in the future.
At 72 I can be reasonably sure I will not get an EV other than my e-bike and mobility scooter, but younger generation likely will at some time need the extra cores on the supply so an EV charging point can be fitted.
