Bathroom latch
AidanOrton
Bathroom latch
Post by AidanOrton »
Hi
Newbie here, so please be gentle.
I'm in the middle of a bathroom refit and I dislike having pull cords, but the problem with light switches outside the room is someone can switch the light off when you're in the shower with the door locked.
I have an idea that if I have a normal external light switch and a micro switch on the door I could latch the light on until the door is open.
In an ideal world, with the door open the external switch would behave as normal and with the door closed its state would be latched until the door is open.
A latching relay feels the way to go, but if anyone could offer advice or knowledge of any regulations preventing this, it'd be appreciated.
Thanks,
Aidan
Has thanked: 831 times
Been thanked: 3628 times
Bathroom latch
Buy a movement detector bulb, about a fiver.
Has thanked: 48 times
Been thanked: 2604 times
Bathroom latch
Seems an odd thing to do, but if you want to, that would be up to you, providing everything is suitably protected. You could of course have a normal switch, provided it is more than 60cm from the edge of the bath, and the circuit is RCD protected.
OnlyMe
Approved Electrician
Has thanked: 225 times
Been thanked: 664 times
Bathroom latch
Post by OnlyMe »
AidanOrton wrote: Tue Apr 02, 2024 6:51 pm Hi
So? Either break their fingers or put the lightswitch on the inside.
AidanOrton
Bathroom latch
Hmm, shame not to have a solution to the idea raised, but some interesting feedback.
Despite being a decent sized bathroom, there's not zone 3 space around the door for a normal light switch and I don't fancy flapping my arms around from the bath\shower to get the lights back on, but passive \ low voltage switches in zone 2 seem to be an option, so I'll investigate those.
Thanks.
Bathroom latch
Well for a fiver it is worth a go, my porch light is very sensitive to any movement and in a bathroom, there is detectable movement, unless you have a shower curtain. You could maybe go a step further and look at a smart LED bulb that you can control with your phone or Alexa. Have a look at this one from Argos https://www.argos.co.uk/product/1931738 ... R=plp:9:36
Bathroom latch
AidanOrton wrote: Wed Apr 03, 2024 7:21 amthere's not zone 3 space around the door for a normal light switch
There is no zone 3, that is why I said as I did. Zone 3 went with the 17th edition
AidanOrton
Bathroom latch
Someone-Else wrote: Wed Apr 03, 2024 9:07 am
Sigh, pedant award goes to.. Anything outside zone 2, not in a zone, safety zone, non-wet area, call it what you will.
OnlyMe
Bathroom latch
Post by OnlyMe »
AidanOrton wrote: Wed Apr 03, 2024 6:15 pm Sigh, pedant award goes to.. Anything outside zone 2, not in a zone, safety zone, non-wet area, call it what you will.
So you mean it's a tiny bathroom then?
AidanOrton
Bathroom latch
OnlyMe wrote: Wed Apr 03, 2024 6:43 pm
2.25m x 3m, tiny?
Return to “Lighting”
