What to use in this hole of the slab
kevin93429
Has thanked: 24 times
Been thanked: 1 time
Post by kevin93429 »
Hi
This where the gas meter was before it was moved to an exterior location. Cadent came to view the rusty steel pipe and below the meter and moved the meter and replaced the pipe with plastic to gas mains.
The slab is two layered, with a DPM in between the two. How should I and what should I use to 'pack' the hole before adding concrete/DPM please? Thanks in advance.
stevei
Has thanked: 86 times
Been thanked: 116 times
Post by stevei »
Where is the hole and what is at the bottom of it?
kevin93429
The hole is in the interior of the extension, against an exterior wall, with an interior wall at a right angle to the exterior wall. At the bottom of it feels like sandy detritus.
stevei
Post by stevei »
Will you or anyone else need access to the hole at any time?
Has thanked: 807 times
Been thanked: 3498 times
Will the area take any load? If not then consider putting a hard substrate like a roof tile to span the hole. Lay concrete over this and then finish with a membrane and screed to match the surrounding floor levels.
kevin93429
There's no need for access to the hole going forward.
I hadn't thought about a hard substrate like roof tile, sounds like a good idea, as there won't be load bearing there in the corner.
Thanks very much!
Return to “General DIY forum”
