360° White Microwave Sensor Surface Mount fitting
mani222
Has thanked: 3 times
Post by mani222 »
Hi guy's I'm looking to fit this light sensor, there are four terminals on the sensor
mani222
Post by mani222 »
ImageBut only two wires in my light switch, blue going to L1 and brown com
mani222
Post by mani222 »
Do I need to add a 4 core cable going from light to sensor?
mani222
Post by mani222 »
Has thanked: 47 times
Been thanked: 2591 times
If you did install a 4 core, where would the other two go?
In short, you have a normal switch, 2 wires. One is permanent live, the other goes live when you operate the switch (Pull the string) this one is called switched live.
Your movement sensor requires Live, Neutral and switched live. You would have to do some re wiring, or put the switch back.
mani222 (Thu Apr 25, 2024 10:19 pm)
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
That sensor needs a neutral, which you don’t have at your switch
These users thanked the author Neelix for the post:
mani222
Post by mani222 »
Thanks both, can I pull natural from the light fixture?
ericmark
Been thanked: 783 times
Post by ericmark »
I am sure you could pull in another cable, however I would look at putting the PIR next to light which has got line and neutral wires, and leave old switch where it is.
Not sure why you want a PIR, there are some advertised to work without a neutral.
These users thanked the author ericmark for the post:
mani222
Post by mani222 »
OK Which of the four terminals should I use, say at the switch would I connect to L and N on sensor and new neutral to N-Load on sensor?
Return to “Lighting”
