Moving a light switch.
Rorschach
Has thanked: 107 times
Been thanked: 1038 times
Post by Rorschach »
I need to move a (double) switch about 8" to the side of it's current location so I can put in a bookcase. What is going to be the best/easiest way to do this? The wires are buried in a solid concrete wall so I do have the option of moving behind plasterboard etc.
I don't mind making it a temporary solution that can be reinstated back to original if/when I move.
Neelix
Has thanked: 117 times
Been thanked: 212 times
Post by Neelix »
Chase the wall for the cable to run horizontally from the existing position. Use Wagos to connect the new cable to the old cable. Use a 1G blank to cover the existing back box and connections.
Fit the switch in the new position
These users thanked the author Neelix for the post:
Rorschach (Mon Apr 29, 2024 6:44 am)
Rorschach
Post by Rorschach »
I think the edge of the bookcase is going to fall right on the where the switch currently is. Do they made 1G covers that will fit flush to a wall? I had thought about putting a piece of thin board and then a light skim of filler so it would be easy to knock out in the future.
Has thanked: 47 times
Been thanked: 2556 times
Rorschach wrote: Mon Apr 29, 2024 6:48 amDo they made 1G covers that will fit flush to a wall?
Not that I am aware of. The idea of a flush faceplate is not only to cover the hole/stop the wires being poked, but to indicate that there is a cable behind it. If you put something else over and decorate it, today you know it's there, "next month" you will forget and...........
Neelix
Post by Neelix »
Rorschach wrote: Mon Apr 29, 2024 6:48 am I think the edge of the bookcase is going to fall right on the where the switch currently is. Do they made 1G covers that will fit flush to a wall? I had thought about putting a piece of thin board and then a light skim of filler so it would be easy to knock out in the future.
The blank plate is thinner that the skirting board, so it shouldn’t be an issue
Rorschach
Post by Rorschach »
Neelix wrote: Mon Apr 29, 2024 8:25 am
The bookcase will be mounted to the wall.
Rorschach
Post by Rorschach »
Someone-Else wrote: Mon Apr 29, 2024 7:16 am
Don't worry, I won't forget.
It's not you I am worried about.
stevei
Has thanked: 86 times
Been thanked: 116 times
Post by stevei »
Rorschach
Post by Rorschach »
Someone-Else wrote: Mon Apr 29, 2024 10:40 am It's not you I am worried about.
Who then?
Rorschach
Post by Rorschach »
stevei wrote: Mon Apr 29, 2024 1:28 pm What about one of these <span class="skimlinks-unlinked">https://www.screwfix.com/p/lap-1-gang-b ... w.ds</span>
Hmm, yes maybe!
Scotty001
Has thanked: 26 times
Been thanked: 173 times
Post by Scotty001 »
Rorschach wrote: Mon Apr 29, 2024 4:16 pm
Who then?
Anyone in the future
(your family members, new owners)
that may try to put something in to the wall in that location (backbox across to the new switch)
they won't be expecting that kind of cable route.
They may get a little shock (physically and mentally)
Rorschach
Post by Rorschach »
I would be reinstating the original switch position before I sell the property. There are several (perfectly safe) electrical installations that will be removed before selling.
ericmark
Has thanked: 116 times
Been thanked: 782 times
Post by ericmark »
Rorschach wrote: Mon Apr 29, 2024 8:14 pm I would be reinstating the original switch position before I sell the property. There are several (perfectly safe) electrical installations that will be removed before selling.
I am sure my late dad said the same, but he never got the option.
Rorschach
Post by Rorschach »
ericmark wrote: Fri May 03, 2024 2:28 pm
I'll be sure to add a note to my will.
Return to “Lighting”
