Dust Extraction Whilst Drilling
parkgate
Has thanked: 60 times
Been thanked: 6 times
Post by parkgate »
Can anybody recommend a drill dust extraction system as we are fitting additional external lights to our house?
The previous problem we had, when we fitted the security cameras, is that when the holes were drilled the resulting red brick dust stained the white render on the walls.
I have seen the Bosch Professional system, but this may be over the top for our requirement.
Comments would be appreciated.
Kind Regards,
Has thanked: 831 times
Been thanked: 3628 times
I used a rubber cup thing once that worked well. They are better now, have a look at this https://www.amazon.co.uk/dp/B09YTWYXYZ/ ... F9kZXRhaWw
parkgate (Fri May 10, 2024 1:11 pm)
parkgate
Post by parkgate »
dewaltdisney,
Thank you for your prompt reply.
I will have a look at this.
Regards,
Has thanked: 740 times
Been thanked: 2355 times
old fashioned envelope
if you hold the top open and make a "/\"underneath back to front with a finger then masking tape to wall under hole
Return to “Tool Talk”
