Disconnecting fuse spur problem
Posted: Wed May 29, 2024 7:48 pm
We are decorating my daughter's bedroom this weekend and so I wanted to remove a fuse spur which was on the wall. I presume in the past the owners had a tv or something on the wall.
There were wires coming into it from the loft space but nothing coming out of it.
I presumed I could isolate the wires using one of these https://www.amazon.co.uk/dp/B0BCTXBWDL? ... ct_details
So I turned the power off, put the wires into the connector and put the power back on. The 'upstairs sockets' switch on my fuseboard tripped. Putting the RCD and 'upstairs sockets' switch back up and turning the main power switch back on caused the rcd and the socket switch to trip again.
I re-connected the wires and tried them in another connector but the same thing happened.
Rather in panic mode as to what I'd done I connected the cable back to the fuse spur in the loft (just sitting on a joist for now) and all was fine.
I have no idea what the cable is for and it runs under loft boards so it's not easy to trace but is there a way of isolating it without having it plugged into a fuse spur or is that the only option? If so, I need to get a new spur as this one has a crack in it and screw it to a joist so it's out the way (assuming it's safe to do that?)
