Advice on filler
- Been thanked: 1 time
Advice on filler
Hi, I’ve recently done some work on my stairs and need some advice on an appropriate filler to go between the Lincusta wallcovering and the wooden stair case. After neatening up the wallcovering, these gaps were found. Is there a special one out there that as to be used. Can anyone recommend a good filler for this particular job? Thanks in advance
- 20240605_113141.jpg (38.46 KiB) Viewed 502 times
- 20240605_113134.jpg (41.63 KiB) Viewed 502 times
- 20240605_113130.jpg (43.15 KiB) Viewed 502 times
- 20240605_113125.jpg (47.62 KiB) Viewed 502 times
- Has thanked: 825 times
- Been thanked: 3570 times
Advice on filler
Sorry about the late reply to this. Just want to tell you that what you suggested worked. Thanks
- These users thanked the author Woody2317 for the post:
- dewaltdisney (Thu Oct 03, 2024 5:41 pm)
