Drilling into potentially concrete internal walls
xmint
Post by xmint »
I have been putting in some screws to hang some pictures and one of our internal walls is way more solid than the rest and I can't seem to drill in enough to put a rawl plug in. Using a masonry drill bit it seems to stop and start to drift about 9/10mm in. Any advice would be great! It is a flat built in the 60s and this seems to be the only section of wall that is like this internally. Sadly we do not have any detailed information on the makeup of the walls. The Bosch metal detector we have seems to be triggered by the wall overall but it is a wall with no electronics/looks like it might be due to metal in the wall?
Attached are some images of the hole;
IMG_2781 - Copy.jpg (99.78 KiB) Viewed 447 times
IMG_2787 - Copy.jpg (180.1 KiB) Viewed 447 times
IMG_2780 - Copy.jpg (101.61 KiB) Viewed 447 times
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
It looks like you've hit the steel re-bar which is there to give strength to the concrete. Try drilling an inch or so from that point.
By eck! ©
Return to “General DIY forum”
