Hi.
We have a driveway leading to a back yard which has and area of 170m2. The overall area is just shy of 400m2. This will mostly be surfaced using 10mm SMA.
However, there is part of the yard at rear which I'm covering surfacing with a contrast to the SMA. This contrast area will be mostly pedestrian for access to a patio area, garage and vehicles. I'd like for it to have increased grip for elderly family member to walk on during wet weather and winter.
We have ruled out paving slabs as neither of us like them, and probably similar for block paving too.
So the question is what type of surface could we get out down that would fulfil the brief and have good longevity?
It will be an area of approx 90m2. The remainder will be SMA.
I had thought that rain bound gravel would be an option, but I have doubts about it due to its longevity and long term cleanliness. Am I right to be concerned or is that unfounded?
One person I spoke to, just suggested a cobble bordering SMA to delineate between the areas of SMA.
Thoughts and suggestions would be greatly appreciated.
Thanks in advance.
Driveway surfaces
- Has thanked: 30 times
- Been thanked: 2 times
- Has thanked: 807 times
- Been thanked: 3496 times
Driveway surfaces
Have a look at grids https://www.ultimate-one.co.uk/grass-re ... -c-103_147
They come in various densities and they can either be soil filled for grass or gravel filled if preferred. The main thing is that the waffle will create a strong firm surface that you can form to your needs.
Driveway surfaces
That was an option at start but I don't think the colour options suit a domestic setting.
I've found a resin installer who has 10yr guarantee on tarmac and 21yr guarantee on the resin. I've also found an installer who uses coloured asphalt - although like the anti skid surface, the appearance of the coloured tarmac - uniform single colour - might not look the best in a domestic setting.
