Any ideas on how to fill in this small hole. See the attachment. It'sabout 1 to 2 cm across
It's where the former owner tried to fit the light switch and obviously had to move the switch. The screws only just hit the joists above.
I can't get to it from above
Filling in this small hole
- Has thanked: 807 times
- Been thanked: 3496 times
The best solution would be to let in a plasterboard patch by removing the fitting and refixing it after you have made good.
