Antique Brass Screws
- Has thanked: 30 times
- Been thanked: 2 times
I need to get a couple of bras screws to hold up a light in living room.
When installed the electrician only had zinc screws. I'd like to get them replaced with more suitable ones now.
Where would I get some screws that would suit this job. Looks like they'd need to be some heavy duty screws to match up with those already in use.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2333 times
untreated brass screws will look worse as brass is a goldy yellow colour
perhaps slotted phosphor bronze coloured screws ??
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2556 times
Screwfix? B & Q (if you only want 2) or ebay
- Has thanked: 20 times
- Been thanked: 13 times
That's what I'd do: If you get in the ballpark colourwise no one will ever notice.
- Has thanked: 807 times
- Been thanked: 3496 times
Brass screws are so soft the slot gets chewed up easily, painting is the answer. It is only you who will look.
- big-all
- Pro Carpenter
i fully agree with this commentdewaltdisney wrote: ↑Wed Jun 19, 2024 11:19 am Brass screws are so soft the slot gets chewed up easily, painting is the answer. It is only you who will look.
this is why when using brass you always predrill a hole then use a modern screw to open the hole to minimize the risk
further to this most stained or coloured screws you buy wont be brass because off the cost and softness
