Removing bathroom shaving socket
Hi, I have a shaving socket in my upstairs bathroom that we do not use. I am currently repainting and am thinking about removing it. What would be the easiest way to do this? I found the point in the loft that I think is feeding the bathroom lighting as well as the shaving socket. Picture attached. I found a note next to it that seems to explain some of the wiring, although I don’t know what the abbreviations in the note are supposed to mean.
- IMG_4354.jpg (269.43 KiB) Viewed 671 times
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2571 times
It looks like it is the colours of the wires in the terminals. (Doesn't mean anything though)
Are you sure you want to remove the shaver socket? Its just if you do, you will have a gaping hole left in the wall.
Assuming you want to go ahead, you need to trace the cable that feeds the actual shaver socket, disconnect it from where it is supplied from THEN (and only then) you can remove it and fill in the hole.
- Someone-Else
Since it is a ceiling rose, I would guess the cover has long gone into the bin as it "won't fit"
- Someone-Else
Why ask? This one is in the loft.
- wine~o
- Has thanked: 1414 times
- Been thanked: 4017 times
yartin, at best guess the feed to the shaver socket is the darker of the 2 blues and the yellow at the ceiling rose. Please confirm this is the case by removing the shaver socket cover and checking that the colours match ... LECKY OFF.
If you can confirm what i suspect then just disconnect wires as a bove at the ceiling rose.
- Has thanked: 144 times
- Been thanked: 126 times
I tried didn't work.wine~o wrote: ↑Tue Jun 25, 2024 10:09 am yartin, at best guess the feed to the shaver socket is the darker of the 2 blues and the yellow at the ceiling rose. Please confirm this is the case by removing the shaver socket cover and checking that the colours match ... LECKY OFF.
- wine~o
yartin, what didn't work? were the core colours at the shaver socket different ? Are you sure that the shaver socket is fed from that ceiling rose ?
