How to remove this alarm sensor?
ljrc
Has thanked: 9 times
Post by ljrc »
We moved into our house five years ago and have never used our alarm system. I want to remove this sensor permanently from the ceiling. Is this something I can do without using an electrician? Maybe cutting the wires and covering the ends with electrical tape or something?
To my knowledge the alarm has never been “set” or “configured” and has not gone off in our time living here.
Neelix
Has thanked: 117 times
Been thanked: 212 times
Post by Neelix »
If you just cut the cable, and if the unit has power, either from the mains or it’s internal battery, the Saunders WILL go off
Do you have the access code for it ?
ljrc
Post by ljrc »
Yes I have the access code thankfully! Ok maybe I get an electrician in to remove the whole system
Return to “General DIY forum”
