Hi, I was wondering, what do you mean by installed the gaskets incorrectly? There is only one way, right?
I ask because I have the same problem. I've installed 2 different egr's now and both rattle like crazy when idling. I have tightened the bolts of the connections with the gaskets first, and then the mounting bolts. There does not seem to be a leak anywhere, I've even tested it with soapy water.
It's driving me nuts! Do you have any suggestion?
Rattle after EGR valve replacement
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 569 times
It's considered bad form to dig up old threads. I've started you a new one. Original can be found here viewtopic.php?t=106675
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2590 times
Also, Jdm2803's last appearance on this forum is the one you replied to, so it is doubtful he will ever read your question. (sorry about that) Always look when a poster was last active before you reply.
