Vailant ecoTech plus 831 No CH flow
The1GDP
Post by The1GDP »
Hi, Ideas welcomed!
Drained down system, changed radiator ensuring correct flow direction for TRV, refilled system, bled new and existing rads, restarted boiler, confirmed thermostat heat demand, boiler fires up, flow pipe gets hot, no apparent flow to system, no heat to pipes, DHW flow correct, no faults evident on display, following day partial drain off hoping to clear any air blocs, refilled, exactly the same symptoms!
I’m lost for any additional actions that might resolve…….. :dunno: :wtf:
Has thanked: 47 times
Been thanked: 2559 times
What about the pump? does that need bleeding?
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
No fault codes showing ? It shows correct pressure? Not sure if this applies to your model/year, but taking it as a combi.
Bleed the heating pump by loosening the central screw. Close the filling valve and the cold water dispensing valve. Be prepared with a towel and a plastic container.
• Loosen the cap of the pump A.A.V. (automatic air vent)(the appliance is ventilated independently by the pump A.A.V. during continuous operation).
Pump AAV.png (46.29 KiB) Viewed 448 times
sammy.se
Has thanked: 90 times
Been thanked: 80 times
Post by sammy.se »
Sounds like it could be the diverter valve?
I bought an original new one from ebay very cheaply
It is always best to establish what is causing the problem, changing parts at random/guess can be expensive and rarely works.
gas4you
Has thanked: 419 times
Been thanked: 900 times
Post by gas4you »
When you turn the boiler on can you hear the diverter valve moving?
Dave
sammy.se
Post by sammy.se »
I recently had my diverter valve changed, hence my suggestion. @gas4you, it's that part the sounds like rapid clicking/door creaking (ish), right?
gas4you
Post by gas4you »
yes
These users thanked the author gas4you for the post:
sammy.se (Mon Jul 22, 2024 11:50 am)
Dave
sammy.se
Post by sammy.se »
If the OP is sill monitoring this thread, tell us what you hear when the boiler starts. Does it click/creak?
