Which jigsaw blades
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 569 times
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2342 times
Which jigsaw blades
you need a fret or coping saw
the best you can do with jigsaw will not give you a close radius
- Has thanked: 32 times
- Been thanked: 807 times
Which jigsaw blades
check out youtube videos there is a blade that works well for it although i cant remember which one... also unless youve got a coping foot attachemtent for your jigsaw youll find it awkward to do anyway.
i always just use my coping saw when ever im fiting skirting boards. with a bit of practice its easy enough to get a super tight joint
- big-all
- Pro Carpenter
Which jigsaw blades
you can use these Bosch T101AO Jigsaw Blades Tight Curve but a nighmare unless you have 3 hands and about 40 strokes a min max
but as i say you cant do tight curves easilly with out the aid off small radius files
- Has thanked: 20 times
- Been thanked: 13 times
Which jigsaw blades
I use one of these for coping pdf skirting & seem to get on OK with it:
https://www.screwfix.com/p/magnusson-15 ... 5mm-/3168v
I found these vids helpful:
https://www.youtube.com/watch?v=QyOfIH9PuyY
https://www.youtube.com/watch?v=qJHc1Q-mQjk
Which jigsaw blades
aye i just go with a coping saw and i do skirting regularly. it does take a while to learn but once its mastered its possible to achieve perfection pretty much every time. especially with mdf skirts.
i normally finish off with a half round file to fine tune if necessary
- Argyll
- Has thanked: 1185 times
- Been thanked: 582 times
Which jigsaw blades
I normally back cut the straight piece about 5 degrees using my mitre saw or you can use a hand saw. Then I cope the remainder out with a coping saw. This is quite good for removing the remainder around the delicate parts.
https://www.amazon.co.uk/dp/B0037MMDIA? ... tails&th=1
