Mask
_Chris_
Has thanked: 181 times
Been thanked: 2 times
Mask
Post by _Chris_ »
From personal experience, have any of you come across a really great mask that is effective against cement dust, sawdust, loft insulation, etc, etc, BUT, is also easy to quickly put on and is 100% effective against the things just mentioned?
Has thanked: 807 times
Been thanked: 3496 times
Mask
The best types are air fed systems but these can work out expensive. Here is a knock off version on Ali Baba https://www.******.com/item/1005003 ... y&src=bing& to give you an idea Our site is blocking the ali express .com as it is a bit spammy. Fill in the gaps with no spaces
_Chris_
Mask
Post by _Chris_ »
Thank you, any other recommendations from anyone else here?
Return to “General DIY forum”
