First post on here and I would have attached it the following thread but it's been locked....
viewtopic.php?t=104100
I have designed a 3d printable Square downpipe convertor that converts from 65mm to 61mm. I.e new money to old money downpipe convertor.
Saved me digging down below ground level to get to my traps.
The file type for the print (.STL) is not supported here so wont let me post it and also won't let me link to where I have posted it as it's on an external website.
Does anyone have any suggestions how I can attach the file or make a link?
Admin?
Good part to have as it really got me out of a jam 8)
Square downpipe convertor 65mm to 61mm
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2571 times
The reason the thread was locked is because it was last active in April 2021 and it was resurrected in August 2021. Resurrecting old threads on any forum is never a good idea, just as well you didn't do it too.
Would it not be true to say that if someone had a 3d printer, and they had the problem you have, would they have not printed one them selves?
- Been thanked: 1 time
Yes they would need to either print it themselves or pay someone to do it for them. The file with the part is free.
This simply saves them time designing the model that needs printed. There was a small amount of tral and error in designing it, so saves them that hassle and is also useful if you're not familar with any design/cad software.
