UPVC Door Adjust Flag Hinge
Onar
Has thanked: 16 times
Been thanked: 2 times
Post by Onar »
Hello guys,
Tried to adjust Flag Hinges on UPVC door with 5mm Allen Key, but when I turn the Allen Key it cannot grip, it just go around in the plastic.
I cannot understand why they use plastic for door adjustment.
Is it possible to get Flag Hinges with metal adjustment/.
Thank you.
Has thanked: 48 times
Been thanked: 2604 times
Onar wrote: Mon Aug 19, 2024 5:48 pmIs it possible to get Flag Hinges with metal adjustment.
Yes. As I do not know what size you want, I suggest look on line, there are lots available.
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
I tried to raise pvc door few months, didn't manage from the flag hinge, then I just lifted the door and put washers and doing the job since.
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Post by London mike 61 »
When you open the door and look at the hinges, you should see maybe two screws which hold the cover of the hinge in place if you remove these screws you will get better access to the adjustment screw.
You will then be able to use your 5 mm Hex key to adjust the door. What I normally find is that you only have to adjust the top and middle hinges where the door has dropped at an angle, rarely have I seen a door that dropped vertically , only at a slight angle.
If the door is quite old then you will only have adjustment for the door dropping at an angle, the older hinges don’t usually have a screw at the top to adjust the vertical up and down.
I hope that helps.
Mike
Return to “General DIY forum”
