Adding second light to switched circuit
mawallace
Has thanked: 1 time
Post by mawallace »
I have an outside light. This feed from a light switch. It's 100w
I would like to add a second light to the circuit in parrell.
Is that okay to do if I take the feed from the existing outside light
Has thanked: 47 times
Been thanked: 2559 times
Yes.
Has thanked: 734 times
Been thanked: 2334 times
as long as you realize parallel means a second light exactly copying the first and will never be other than duplicate without further wiring to separate functions
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Post by Rorschach »
Yep.
Why is it 100W though? Surely not an LED?
Return to “Lighting”
