Trouble closing internal door
- Has thanked: 4 times
Howdy
Looking for tips to fix my lounge door which won't close.
The bottom of the door catches the floor, and it takes great effort to push it into the door frame.
The pics show unevenness between the frame and the door at the top, plus what the hinge looks like.
YouTube videos show the presenters tapping a pin from the hinge, which reveals uneven knuckles that can be straightened to match when the door is closed.
My hinge doesn't have a pin I can knock out, instead there is an allen key slot, turning it does not loosen anything.
What can I do?
Cheers
What can I do?
Cheers
- IMG_20240908_102038-min.jpg (58.63 KiB) Viewed 270 times
- IMG_20240908_102025-min.jpg (94.89 KiB) Viewed 270 times
- Has thanked: 807 times
- Been thanked: 3496 times
If the gap between door and frame are even all around then it is an issue with the bottom of the door catching the floor. Is it within your skill set to remove the door and plane it down a bit.
- sergeantsam111 (Sun Sep 08, 2024 6:04 pm)
- Has thanked: 32 times
- Been thanked: 805 times
strange owld hinge that. closest to that ive ever seen is a national hickman hinge.
- These users thanked the author fin for the post:
- sergeantsam111 (Sun Sep 08, 2024 6:05 pm)
Howdydewaltdisney wrote: ↑Sun Sep 08, 2024 2:19 pm If the gap between door and frame are even all around then it is an issue with the bottom of the door catching the floor. Is it within your skill set to remove the door and plane it down a bit.
It is tighter at the top.
I could take the door off and sand some material off the bottom, but that would be a faff
it doesnt look to be to me mate. im a joiner and work in standard houses so domestic rather than site work, never ever seen a hinge like that
- sergeantsam111 (Mon Sep 09, 2024 7:36 pm)
- Has thanked: 201 times
- Been thanked: 499 times
Not a hinge that I’ve encountered as far as I can remember but either way if it’s tight at the top and catching at the bottom of the door faffing around with the hinge is going to be a waste of time , the door needs to come off and have some planed off it.
- These users thanked the author Grendel for the post:
- sergeantsam111 (Mon Sep 09, 2024 7:38 pm)
ah.fin wrote: ↑Sun Sep 08, 2024 10:17 pmit doesnt look to be to me mate. im a joiner and work in standard houses so domestic rather than site work, never ever seen a hinge like that
this is a new build house from Barrat Homes built in 2007. I suspect they bought a load of bits and bobs in bulk on the cheap, some of which is non-standard
