Undersized upvc door
- Has thanked: 5 times
Hi all
I've got the chance of a free upvc door .
It's only 2 year old but my opening is 950cm wide , this door is 880, so as I'm getting the door free is it bad practice to put a 70mm addon on,
It's 210cm high too.
There is a window to the side also attached with a joining addon, if it's OK to do this can the 70mm go hinge side?
So it would be a 70x70 addon
- Has thanked: 107 times
- Been thanked: 1038 times
It probably wouldn't look all that great with a big fillet like that, but as the old phrase goes beggars can't be choosers and if the door is a significant upgrade to your current one then it is probably worth putting up with.
- These users thanked the author Rorschach for the post:
- Nicholas221078 (Mon Sep 09, 2024 8:58 pm)
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2333 times
is it into a clean opening or are you trying to adapt /pad out a wooden frame
also are you setting it up the same way as in was an outward opening door and still will be as the drain holes will drain to what was the front off the door
- These users thanked the author big-all for the post:
- Has thanked: 807 times
- Been thanked: 3496 times
Are you getting the door mounted in its frame as a unit? If so it will be easier to fit into an existing opening but if not, it is not really the best to fix it into a built up frame to suit the door.
Thanks all.
We have a pvcu door at the moment , it does need replacing hence my friend donating it as we've just paid out for electrics etc doing.
Its the same side opening and same opening direction
It's a brick built house , standard brick .
So in a nutshell It's like this now.
Remeber we are refurbing on a budget lol
- 17259153366636792069434368380912.jpg (85.18 KiB) Viewed 276 times
- Has thanked: 86 times
- Been thanked: 116 times
I would fit the filler piece on the handle side. Being between the window and door will not look out of place plus the weight of the door would be better having the frame fixed directly to the brick.
- These users thanked the author stevei for the post:
- Nicholas221078 (Tue Sep 10, 2024 1:17 pm)
I think the hinges would be too close to the plater inside after looking at the door.
Is there any fillers that make up 70mm if I put 1 either side.
You can usually cut down filler pieces, obviously cutting on the side that is going against the brick, not the side that locks into the frame. Depending how much you cut off you might need to add in some material into the hollow space to stop the screws pulling through.
- Nicholas221078 (Wed Sep 11, 2024 7:28 am)
