fuses
simbarb1
Has thanked: 22 times
Been thanked: 2 times
fuses
Post by simbarb1 »
apologies for the query but im not savvy with this.bought a 4ft tube for the shed@18w input at 220-240 v no info for the fuse, :salute: advice would be great
thanks
Has thanked: 47 times
Been thanked: 2559 times
fuses
Depends what you will be connecting it to.
If you are adding a plug, put a 3Amp fuse in the plug.
If you are adding it to the lighting circuit/changing an existing light, it should already have a 6Amp mcb
ericmark
Has thanked: 116 times
Been thanked: 782 times
fuses
Post by ericmark »
230 watt = 1 amp, so standard BS 1362 fuses come in 1, 2, 3, 5, 7, 10 and 13 amp and the preferred sizes are 3 and 13, so 3 amp would normally be used, but even a 1 amp would be ample.
Return to “Lighting”
