DIY kitchen gas hob fitting.
Damo3716
Post by Damo3716 »
Hi all. I'm renovating my kitchen and have a question. I would like a 5 ring gas hob and the smallest I can find is 700. Can I install a 700 hob over a 600 cabinet? If so, what adjustments would I need? I'm guessing some sort of cut out of the neighbouring cabinets either side to allow it to sit deep enough? Thanks in advance.
Has thanked: 47 times
Been thanked: 2556 times
NO.
stevei
Has thanked: 86 times
Been thanked: 116 times
Post by stevei »
Try to get hold of the fitting instructions for the hob before you buy. They should tell you if it will fit.
Screenshot 2024-09-29 093159.png (154.57 KiB) Viewed 101 times
The Cookology one in this screeshot looks like it could fit. You will need a gas safe fitter to connect it. I believe hobs need solid pipework for the gas supply.
wine~o
Has thanked: 1414 times
Been thanked: 4015 times
Post by wine~o »
Good advice from Stevei , however you will also need to take into account any cabinetry etc. above the hob, you need 50mm clearance above on both sides of the hob.
etaf
Has thanked: 37 times
Been thanked: 146 times
Post by etaf »
i have 2x 600 cabinets with a 900 5 burner gas hob over the two , pretty much center of the 1200 width
can you show how you plan to put the 700 over the 600 cabinet , does the worktop overhang - or is it just a run of cabinets and the 700 happens to span 2 cabinets
Simple DIYer
Wayne
Return to “General DIY forum”
