Lifting paint
- Has thanked: 11 times
- Been thanked: 1 time
Lifting paint
Hi everyone,
I’m hoping some of you guys might be able to help?
I’d put tesa yellow tape around the patio doors before caulking and when I peeled it off the old paint just lifted away!
I’m going to be repainting the room but need to know the best way to repair the damage.
Photos included so you can see what’s happened.
Many thanks
https://www.dropbox.com/scl/fi/qwrhk9wx ... 4izcl&dl=0
https://www.dropbox.com/scl/fi/78at0yhl ... z3nl6&dl=0
Many thanks
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 566 times
Lifting paint
Better to attach the pics.
- f4t1ASsE.jpeg (182.25 KiB) Viewed 280 times
- 2M7-lE28.jpeg (168.2 KiB) Viewed 282 times
- These users thanked the author moderator2 for the post:
- Piscator (Wed Oct 02, 2024 7:33 am)
- wine~o
- Has thanked: 1414 times
- Been thanked: 4017 times
Lifting paint
looks like the original paint was missing a mist coat, as a result the top coat/s have not adhered properly. ( A mist coat is a thinned down layer of emulsion applied to bare plaster) Bare plaster is highly absorbent, if you go over with a full undiluted coat the plaster sucks all the water up and leaves a layer of pigment that is easily removed by tape.'
Sand back as best you can, apply a coat of emulsion (TRADE) thinned by 10-20% leave to dry then over paint.
- wine~o
Lifting paint
when sanding feather in the edges, when painting drag the brush back towards you after doing your up/downwards strokes. it shouldn't leave a noticeable ridge.
- Has thanked: 814 times
- Been thanked: 3508 times
Lifting paint
I was going to suggest a water based undercoat to seal it. Zinnser Gardz would be better than BIN here.
Lifting paint
I see it that the lifting was caused by the tape. It would indicate that the paint under was not bonded well but that does not mean that if you paint over it will peel off on its own. I was saying a bit of water based underocat like you use for the trim would act as an adhesion promoter but in all probability emulsion will do it alone. I always think that the dried emulsion on a stirring stick seems well bonded. You need to watch changing areas of absorption as you can get ghost marks showing the undercoat.
- Piscator (Wed Oct 02, 2024 2:56 pm)
