2D Square 4-Pin GR10q correct fuses
- fender62
- Has thanked: 3 times
what are the correct fuses for 28w 2D Square 4-Pin GR10q lamps bulbs etc, there are many on amazon, can someone link to the correct ones i need please
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2333 times
the correct fuses ???
are they on a lighting circuit?? then 5amp mcb/6 amp fuse as a total circuit protection
on a plug in you are protecting the cable perhaps 3 or 13 amp
28w is nowt in real terms assuming 230v as 1 amp at 230v is 230w so 8 28w bulbs are 1amp[224w]
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2556 times
As big-all almost said, why do you think you need a fuse?
If it's to go in an existing light fitting, no fuse required. (Where would you put said fuse?) If you are putting it in new light fitting on a lead with a plug then a 3A fuse should go in the plug.
- fender62
sorry i should have been more specific, inside the ceiling light fitting it takes the little cylindrical starter fuse.
- light.jpg (109.55 KiB) Viewed 196 times
- Someone-Else
That is NOT a fuse. That is known as a starter. (It warms up, goes open circuit causing the inductor to "collapse" which creates a high voltage, striking the tube.) They don't often fail, if it has get one the same as the one that is there. (I haven't seen one for 10+ years) But to be honest, I would change the whole light fitting to something with LED's, less trouble.
- fender62
thanks for reply, problem one unit keeps blowing bulbs after a few weeks of use, i was thinking maybe the starter is not makeing proper contact or soemthing ? no idea, why would a lighting unit keep going through bulbs regarless of brand bulb. i agree should be replaced with led.
- Has thanked: 98 times
- Been thanked: 872 times
TBH change the fitting to a LED unit, miles more efficient, next to no maintenance and gives off miles better light
https://www.tlc-direct.co.uk/Main_Index ... index.html
https://www.screwfix.com/p/4lite-led-wa ... 18w-1847lm
- Someone-Else
Incompatibility, and poor quality of lamp.
A bad transformer, voltage spike, those 4D bulbs are not cheap and not long before they are phased out, bill him for bulbs fit a new fitting
- Someone-Else
Not your problem, change the lamp again, and send them the bill. Do tell them you know they are wasting money.
