Repositioning isolation switches in the loft
WhoDaresWins
Has thanked: 16 times
Been thanked: 2 times
Post by WhoDaresWins »
I have two shower vent fans in the loft together with the isolation switches. However, the electrician screwed them down to some floorboards. I’m planning on renewing all of the insulation in the loft and as there isn’t any underneath this small section of floorboards, I’d like to reposition the insulation switches. The cables go directly into the back of them. Will I need different switches to mount them near the fans instead?
Any help would be hugely appreciated.
Neelix
Has thanked: 117 times
Been thanked: 212 times
Post by Neelix »
Repositioning them may mean longer cables are required
Just push insulation under this board
Return to “Electric Forum UK”
