Replaced 3 port valve, now no power
- Has thanked: 2 times
Hi everybody, I have just replaced a 3 port motorised valve, I replaced the wires one at a time as I took the old ones out but I have no power going to the pump or boiler. I have valves to isolate the water going to the motorised valve and wondered if I could still have an airlock or is it something else. there is resistance on the motorised valve, any help would be appreciated, thanks.
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 569 times
Alan Dale, I have started you a new thread and changed the title.
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2590 times
Have you actually checked for voltage at the valve? (If so, what with?)
- Alan Dale (Fri Oct 25, 2024 11:42 am)
- Has thanked: 118 times
- Been thanked: 215 times
Have you tripped a circuit ? Blown a fuse ?
Thanks for responding. On the multimeter I have 240v on terminal 8 (orange). 75 v ??? on terminal 7 (grey) 240v on terminal 5 (white). Blue terminal 2, earth terminal 3. I can hear the valve working when I turn the power on. I reset the boiler and have power to it now. Thanks
