Painting over paper/dark paint
Beav
Has thanked: 52 times
Been thanked: 3 times
Post by Beav »
Hiya,
we currently have a home DIY project planned.
Part of the house is a dark purple colour and other are rooms wallpapered.
We are aiming to paint over the wallpaper as i'm aware it could open a can of worms stripping it first. Some rooms have had smaller radiators installed which is exposing non-wallpapered sections, not sure the best way to deal with where the wallpaper stops short of the radiator?
For the darker purple walls we were thinking using Zinsser 1-2-3 primer first then paint it the colour we actually want (it does seem quite an expensive product).
For the wallpapered rooms we aim to stick the paper down in any areas it's slightly lifted then user Zinsser wallpaper cover up then paint the final colour we want. I've used Zinsser products before and they aren't cheap but do seem to work really well.
Would you say this is the best way to deal with it, some say some use white emulsion for the ceilings/walls first then paint the final colour :dunno:
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Post by wine~o »
stick with the zinsser for the papered walls, for the painted walls just go over with TRADE white emulsion, one or two coats as required, then your chosen finish coat.
Beav (Sun Nov 10, 2024 8:27 pm)
Beav
Post by Beav »
wine~o wrote: Sat Nov 09, 2024 9:43 am Unread post by wine~o » Sat Nov 09, 2024 9:43 am
Thank you.
Not 100% sure the best way to prepare some of the rooms for painting as there is bare wall showing where there used to be a larger radiator (plan is to have gas put back in) or parts of the wallpaper have been pulled off. Will 2 coats of paint cover up the line where the wallpaper stops/bare wall starts?
Second Bedroom.jpg (200.34 KiB) Viewed 229 times
Master Bedroom.jpg (211.73 KiB) Viewed 229 times
