I noticed today (behind a piano music stand - so we'd not noticed it before) a round patch in the wall. It looks like a damp patch but doesn't feel damp. I looked at the outside of the exterior wall and can't see anything amiss.
It doesn't feel damp, like I say, but the paint is discoloured and very slightly flaky.
The wall was built 4 years ago and there's no other signs anywhere else.
Any ideas what it could be? It's about 1m from the floor.
Strange circular patch on wall
- Has thanked: 2 times
I'll take some photos tomorrow when it's light, but it's an external wall that often has a wheelie bin near it but doesn't at the moment.
There's a narrow passage and the the fence to next door.
This is the external wall. I've marked roughly where the patch is on the inside
- Has thanked: 823 times
- Been thanked: 3563 times
There is no evidence of an apparent damp patch externally. Check the guttering to ensure it is not blocked and flows freely as a blockage might cause spillover that has found its way to the internal wall where there might be a wall tie or a bridge formed to cause the patch. (This is all highly speculative) Are you sure it a damp patch and not the result of a spill from inside? Is it still damp or just a mark?
Thanks - I'll try that. It doesn't really feel damp on the inside so could well be a mark from something, but we're just perplexed as to what it could have been from.dewaltdisney wrote: ↑Mon Nov 11, 2024 1:59 pm There is no evidence of an apparent damp patch externally. Check the guttering to ensure it is not blocked and flows freely as a blockage might cause spillover that has found its way to the internal wall where there might be a wall tie or a bridge formed to cause the patch. (This is all highly speculative) Are you sure it a damp patch and not the result of a spill from inside? Is it still damp or just a mark?
I think I would initially spray it with this https://www.screwfix.com/p/ronseal-400m ... aint/82093 and leave it a while to see if anything happens.
