- Ultimate Handyman Forum Index DIY Forum/Home improvement Plumbing Forum Central Heating & Boilers
- It is currently Mon Mar 31, 2025 6:32 pm
Frost Stat Query
- Has thanked: 196 times
- Been thanked: 7 times
Frost Stat Query
Post by rautospoon »
I have Honeywell Frost and Pipe Stats fitted to the boiler in my loft.
These are presently set at 5°C and 25°C respectively to accord exactly with the manufacturers instructions.
My query is, are these recommended figures a bit "cautious" and, if so could I safely and reasonably "turn them down" to "say" 3°/4° C or 15°/20°C respectively, in order to save a bit of gas or am I best to "stick 100%" with the recommended figures ?
Many thanks.
Many thanks.
rautospoon
- Has thanked: 831 times
- Been thanked: 3627 times
Frost Stat Query
It only becomes an issue when you get to external minus temperatures. If the boiler is in use then, there would not be an issue as the latent heat in the boiler and pipes will prevent any frost damage. The frost guard is there to kick in if the boiler is off and low temperatures alert it to a possible freeze. If you intend to leave the house empty for a period in the coldest months, perhaps when you are skiing in Klosters, you would need it on a good frost prevention level. To give you an idea I was executor for my late uncle and his bungalow was empty through winter. When I saw that we were in for a freeze I left the room stat on low and although the property was cold, the heating pipes were tepid heat and this prevented any frost damage.
- Someone-Else
- Has thanked: 48 times
- Been thanked: 2604 times
Frost Stat Query
I look at it that if the heating comes on at 5 degrees to stop it freezing then I would rather let it come on than for it to come on too late and have a pipe burst. It's not like it's going to be on for days. My frost stat can't go any lower than 5. I also have a "pipe warming cable" on my condensate pipe, my neighbour doesn't and a few years ago, his condensate pipe froze.
Frost Stat Query
Thanks for the reply and the info. I fully understand the "workings of" and the need for/reasons behind frost stats, but would still appreciate a specific answer to the query I posed in my original post.dewaltdisney wrote: ↑Tue Nov 12, 2024 1:27 pm It only becomes an issue when you get to external minus temperatures. If the boiler is in use then, there would not be an issue as the latent heat in the boiler and pipes will prevent any frost damage. The frost guard is there to kick in if the boiler is off and low temperatures alert it to a possible freeze. If you intend to leave the house empty for a period in the coldest months, perhaps when you are skiing in Klosters, you would need it on a good frost prevention level. To give you an idea I was executor for my late uncle and his bungalow was empty through winter. When I saw that we were in for a freeze I left the room stat on low and although the property was cold, the heating pipes were tepid heat and this prevented any frost damage.
rautospoon
- Someone-Else
Frost Stat Query
No.rautospoon wrote: ↑Tue Nov 12, 2024 1:57 pmbut would still appreciate a specific answer to the query I posed in my original post.
Frost Stat Query
Thanks for the info and the reply. My frost stat can go down to 3°C and I have Armaflex HT insulation on my condensate pipe.Someone-Else wrote: ↑Tue Nov 12, 2024 1:56 pm I look at it that if the heating comes on at 5 degrees to stop it freezing then I would rather let it come on than for it to come on too late and have a pipe burst. It's not like it's going to be on for days. My frost stat can't go any lower than 5. I also have a "pipe warming cable" on my condensate pipe, my neighbour doesn't and a few years ago, his condensate pipe froze.
A specific answer to my original post would be useful.
rautospoon
- Someone-Else
Frost Stat Query
Norautospoon wrote: ↑Tue Nov 12, 2024 12:55 pmMy query is, are these recommended figures a bit "cautious"
Stick with as israutospoon wrote: ↑Tue Nov 12, 2024 12:55 pmand, if so could I safely and reasonably "turn them down" to "say" 3°/4° C or 15°/20°C respectively, in order to save a bit of gas or am I best to "stick 100%" with the recommended figures ?
- rautospoon (Tue Nov 12, 2024 3:32 pm)
Frost Stat Query
The simple answer here is if the boiler is under warranty follow the maker's recommendations, if it is out do what you want.
Frost Stat Query
The manufacturers instructions I quoted were from Honeywell not the maker of the boiler (Vaillant) which is 6 months old and "under" a 10 year guarantee.dewaltdisney wrote: ↑Tue Nov 12, 2024 3:28 pm The simple answer here is if the boiler is under warranty follow the maker's recommendations, if it is out do what you want.
rautospoon
- Has thanked: 419 times
- Been thanked: 900 times
Frost Stat Query
I used to leave the pipe stat set to 10c and the frost stat to 2c.
Never had a problem in 20 odd years
- These users thanked the author gas4you for the post:
- rautospoon (Tue Nov 12, 2024 4:40 pm)
Dave
gas4you
Frost Stat Query
Thanks for that - where exactly was the boiler and was it in a location prone to cold temperatures ?
rautospoon
Frost Stat Query
In garages and lofts
- rautospoon (Fri Nov 15, 2024 5:42 pm)
Dave
gas4you
rautospoon
