Can my PIR be disabled, to switch on and off by switch?
Locked
RJNo3
Post by RJNo3 »
I have an outside light with a switch inside. If I switch the switch back and forth about 4 times, the light stays on. Then, after about 8 hours it goes off and back to sensor.
I do not want the sensor light at all. I just want to use the inside switch to switch it on and switch it off.
Can I alter the light itself? Or do I have to buy another light? Will I need to do anything with the internal light switch?
I attach a photo of what I found when I opened it and a photo of the light and it's description.
Thank you.
Neelix
Has thanked: 118 times
Been thanked: 219 times
Post by Neelix »
Almost certainly
RJNo3
Post by RJNo3 »
How please?
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
Has thanked: 48 times
Been thanked: 2604 times
RJNo3 What you ask can be done, but you would need to identify which wires do what in your light. As you have no means of testing (If you had, you wouldn't be asking here) It would be easier and safer for your self to buy just a light fitting and lamp.
The video mentioned explains how to connect a standalone PIR and a switch, which is not what you have.
RJNo3
Post by RJNo3 »
Managed to work it out. Once I took the back plate off I could see the grey and white wires went to the bulb. The red blue and brown went down to the PIR.
On the original connector at the top, the blue neutral was linked to the white. The grey was linked to the live brown as was the red.
Didn't need the red because I was disabling the PIR.
So I wago clipped the blue and white and the grey and brown. Red out of use.
All works on and off on the switch now.
OnlyMe
Approved Electrician
Has thanked: 225 times
Been thanked: 664 times
Post by OnlyMe »
Someone-Else wrote: Sun Dec 01, 2024 2:49 pm RJNo3 What you ask can be done, but you would need to identify which wires do what in your light. As you have no means of testing (If you had, you wouldn't be asking here) It would be easier and safer for your self to buy just a light fitting and lamp.
There is no need to test or identify anything
Slight edit > Mod 2.
Locked
Return to “Lighting”
