Central heating at home: one of the heaters wouldn't emit heat
first of all I would like to explain the situation in order to possibly help you determine what could cause the problem.
The central heating and the heaters are fairly new, everything has been fitted 5 years ago. Heating is turned on very rarely.. just a few times a year (mainly during winter months).
So for remaining 9 month it would be off. The last time heating was on - all the heaters were working fine. However I turned it on yesterday (after 9 month gap) and one of the heaters wouldn't emit heat at all (nor at the bottom nor anywhere). Thermostatic valve is turned on to the fullest, lockshield also. Water supply reaches the heater (as after barely pulling the hose, that is connected to the lockshield, out you can see that water starts dripping).
I don't understand why would it stop working out of nowhere. Since no adjustments or any work have been done to it since the last time its been used. And last time it worked fine.
Also, I never knew till now, that you need to bleed heaters on a regular basis? I have never bled them in 5 years. Could that be the cause?
Thanks for any info
Thanks for any info
