Damp around velux windows
James11
Has thanked: 37 times
Been thanked: 1 time
Post by James11 »
Hi, the bottom corners of my velux windows do this every year. Is there a simple fix or do i need to get a window specialist in to have a look.
Has thanked: 831 times
Been thanked: 3627 times
It looks like it is either letting a little bit of moisture through or it is condensation. Probably condensation as it would be a cold spot there. Clean back with dilute bleach solution to kill the mold spores and paint over when dry.
OnlineOnline
James11
Post by James11 »
Thanks mate
fin
Has thanked: 32 times
Been thanked: 816 times
Post by fin »
they shouldnt leak. if it happens every year id be asking someone who actually knows velux windows to have a look. the instructions are pretty specific and also the flashing kits also are pretty specific. if the pitch is too low for example some flashing kits are unsuitable.
OnlineOnline
